Both axles and the transmission cover are back on the H tonight.
It was not looking good earlier. The cover gasket shrunk, the brake seal was wrong and the axle seal was wrong. I put all the shafts back in and will put the correct seals in when I get them.
I tried welding a nut on the bolt that twisted off, but it just twisted off below the nut. I ended drilling it out and running a tap to clean it up.
