TractorLinks.com
Show Parts for Model:
Re: valve cover c123
tuckaway
12-02-2012 13:20:57
thanks valve cover will not bottom down feels like something in way? any ideas
gene bender
12-02-2012 17:23:48
 Re: valve cover c123 in reply to tuckaway, 12-02-2012 13:20:57
Are you putting it on backwards give it a half turn the nuts on the rockshaft hold down the rocker assy. Other hold the cover in place.
tuckaway
12-02-2012 18:16:10
 Re: valve cover c123 in reply to gene bender, 12-02-2012 17:23:48
gene,uncle thanks for help, cover turned right to clear oil spout under cover , seems nuts on rocker stops cover from sealing on gasket,would thinner nuts on rocker work to allow cover to seal on gasket?
uncle henry
12-02-2012 19:20:27
 Re: valve cover c123 in reply to tuckaway, 12-02-2012 18:16:10
here is a picture of how much is sticking out of mine
John B.
12-02-2012 19:23:13
 Re: valve cover c123 in reply to uncle henry, 12-02-2012 19:20:27
I don't think he means how much bolt sticks out of the valve cover as much as he means the valve cover is not seating on its gasket.
tuckaway
12-02-2012 19:55:55
 Re: valve cover c123 in reply to John B., 12-02-2012 19:23:13
john b is right , if I take the nuts off the rocker brackets then the cover will snug down on gasket. thanks to all.what am I doing wrong/
uncle henry
12-02-2012 15:40:27
may not have the bolts in the head deep enough
