TractorLinks.com
Show Parts for Model:
Re: Installing SM Pressure Plate Question?
pete_5959
12-02-2012 13:06:13
Do you know what the correct measurement is from pressure plate surface to disk surface? I just had this flywheel resurfaced and the machine shop resurfaced both levels by the same amount.
charlieu
12-02-2012 18:57:47
 Re: Installing SM Pressure Plate Question? in reply to pete_5959, 12-02-2012 13:06:13
I checked my book and the spec I have for the flywheel is 1.406 from the friction surface to the pressure plate mounting surface. Charlie
D Slater
12-02-2012 13:47:39
If the flywheel was cut and not the step, putting washers under the pressure plate would make it worse. Suspect you have a case of the clutch wouldn't release right and someone stuck the washers in hoping to help. Step height 1.406 inches.
