| Farmall & IHC Tractors Discussion Forum |
Topic: Re: have i been wrong all my life?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| MtMan
12-02-2012 05:57:55
184.8.137.172
According to Tractordata.com , Here is what is listed M 25 drawbar and 31-33 on Belt MD 33 drawbar and 38 on belt, Super M drawbar 44 and 47 on belt. Hope this clears things up. |
| gene bender
12-02-2012 06:16:27
207.177.56.85
Re: have i been wrong all my life? in reply to MtMan, 12-02-2012 05:57:55
| I would say tractor data is a joke how can 25hp drawbar pull 3 14 plow like they did. Tons of those "data" site are full of crap poor info and the list goes on. Even the H has more HP than 25. |
| Nebraska Kirk
12-02-2012 17:19:30
207.91.4.159
Re: have i been wrong all my life? in reply to gene bender, 12-02-2012 06:16:27
| Quoting Removed, click Modern View to see
I would not discount tractordata.com. No doubt they got their horsepower figures from the Nebraska Tractor Test results.
Test #328 says the gasoline M produced a maximum 36.07hp on the belt and a maximum of 26.23hp on the drawbar.
Test #333 says the gas H produced a max 19.84hp on the drawbar.
Now, I will say that the almost every H and M has had the engine rebuilt at least once in the past with thinner sleeves and larger pistons thereby giving the engine more cubic inch displacement and thus more horsepower. That is why the M of today can produce 40hp because the engine has been rebuilt to Super M specs. |
| John G. Hasler
12-02-2012 13:22:39
174.124.2.151
| Pull is not power. You can get any amount of pull out of any size engine if you gear it down far enough and give it enough weight and big enough tires. My 544 can pull anything my 560 can and then some. Why? 18.4 tires with 900lb of CaCl solution in each. Yet I"d rather use the 560 for field work. Why? Because it does more acres per hour with a smaller implement than the 544 can with a bigger one. Power equals force times speed. "Pull" is just force. A 1hp winch can outpull your H but you wouldn"t want to plow with it. |
| oldtanker
12-02-2012 13:59:30
66.228.255.239
Re: have i been wrong all my life? in reply to John G. Hasler, 12-02-2012 13:22:39
Aw come on John......get that winch out and try it.....don't foget to post pictures.....LOL. |
| John G. Hasler
12-02-2012 15:28:45
174.124.2.151
Re: have i been wrong all my life? in reply to oldtanker, 12-02-2012 13:59:30
| | Can"t say I"ve tried it or even seen any pictures, but it"s said that plowing was sometimes done in Germany and England around the beginning of the previous century by using a large steam engine to pull a gang of plows across a field with cables. As to seeing if the 544 can outpull a winch, I"d have to find something to rig the winch to that the 544 couldn"t pull out of the ground. I"m not sure I own anything that stout since the old elm died. |
| Leroy
12-02-2012 08:20:51
69.88.205.38
| You go back farther and the 15-30 was rated at the 15 horse on drawbar and it would pull the 3 bottom and later it was rerated at 22-?? and was a 4 plow tractor. |
| Old-F20
12-02-2012 08:53:32
71.7.101.5
Re: have i been wrong all my life? in reply to Leroy, 12-02-2012 08:20:51
you really cant compare pre 39 egines to those of an H or M. they made their power in two different ways. heavy flywheels, long strokes and big bores make for torque monster engines with fairly low HP in regards to thier CID. 15-30's and 22-36's got power from the momentum of a 100 pound flywheel and heavy internal engine parts. one other thing is that the CID of a 22-36 was 425 cubic inches. |
| Leroy
12-02-2012 18:59:08
69.88.205.38
Re: have i been wrong all my life? in reply to Old-F20, 12-02-2012 08:53:32
| All I was doing was talking about the power ratings, not about how they made the power, Rating was still 15 DB HP for 3 bottom and a 10-20 was 10 DB HP for a 2 bottom so you cannot go by ratings. |
| MisterT
12-02-2012 07:28:24
216.248.71.226
Except in this case, "tractor-data" is correct. The horesepower ratings given are NOT actual engine horsepower ratings, but rather the ratings measured where the actual WORK will be taking place. You can go out and buy a garden tractor with a Briggs and Stratton engine that is rated at 25 horsepower, but I guarantee that garden tractor will not do the same work as a Farmall H, and as a further for instance, Before we even had tractors, farmers used horses, and just two big old workhorses were able to pull a one bottom plow, so why would a 25 horsepower Farmall H not be able to pull a 2-14s plow? |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
