| Farmall & IHC Tractors Discussion Forum |
Topic: 6volt IH Farm Truck
[Return to Forum]
| Author |
[Modern View]
| dmiller
12-01-2012 17:51:49
205.162.160.205
Have 1940 IH truck that I use for hauling firewood. Last weekend I was driving between the woods and the house and heard an arcing noise then the truck died. Turned out the battery cable had come loose and bounced off (disconnected). Arced the post up pretty goood. Wouldn't start again. Have worked on it some and found the following. - 6 volts to the coil, - points will spark (bright blue) when I open and close them with a screw driver (when the lobe is set where they should be closed) - No spark at the plugs (best I can tell trying to crank it with a screwdriver jumping the starter button on the firewall. -Testing for continuity I have continuity from the plug inside the center of the cap to the coil end of the coil wire.??????????? |
| Janicholson
12-02-2012 21:08:23
96.24.99.126
Re: 6volt IH Farm Truck in reply to dmiller, 12-01-2012 17:51:49
| The battery was discharged enough to prevent sparking from low voltage when cranking, but not when stationary. No surprise there, a lead acid battery will hold good enough voltage to spark when it is lightly loaded, and drop into no spark when a 350 amp load is applied. Jim |
| dmiller
12-02-2012 19:54:21
107.20.244.8
| Thanks for all the help. I was ready to go to town and buy a condesor on monday. Had put it on the charger overnight, tried it again this afternoon and it started. Not sure why it wouldn't all week but did today. Thankful, dumped the load and parked it inside. |
| LenND
12-02-2012 12:54:35
74.207.160.118
| Not to sound too dumb but is your rotor turning? Len |
| Janicholson
12-02-2012 10:18:18
96.24.99.126
| Pull the coil high voltage wire out of the distributor cap. Put it within i/8 inch of the engine block (tuck it in so you can let go of it and it will stay in place.) now with the key on, move the points from closed to open to get that blue spark at the points. If no blue spark at the coil wire to block, replace the coil. Jim |
| todd Hamilton
12-01-2012 19:25:57
174.254.147.121
| Get a helper to turn it over and watch the points with distributor cap off. If no blue arc when points open you will have no spark. Short could have damaged coil to where it will make some arc but not enough to fire the plugs. Try changing the condensor first |
| 504
12-01-2012 19:43:20
199.127.54.155
Re: 6volt IH Farm Truck in reply to todd Hamilton, 12-01-2012 19:25:57
| Check the coil wire for fire,if the coil wire is firing, then look to the rotor and cap. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
