TractorLinks.com
Show Parts for Model:
Re: Farmall A Cutout Relay Question ...
gene bender
11-29-2012 07:10:27
It doesent give hi charge thats why you set the third brush. How many of those systems have you fixed. Ive been around those systems since 47 and they did come from the factory that way and they still work. The pull cable for the mags was used on the hand crank models with electric start the used a sw. Another quirck the drilled hole in the mags for that cable sw never was discontinued all thru the mag production. Just like the cams in those engines had a lobe for the fuel pump all thru production.
Janicholson
11-29-2012 10:28:12
 Re: Farmall A Cutout Relay Question ... in reply to gene bender, 11-29-2012 07:10:27
Don't be so insistant. Not a flame, I am a very experienced mechanic and electrical system professor. (not that it makes a difference) Jim
gene bender
11-30-2012 03:55:54
 Re: Farmall A Cutout Relay Question ... in reply to Janicholson, 11-29-2012 10:28:12
You still didnt answer the question how many of the cut-out systems do you have and have fixed. Also have you seen any still in their original state.
Janicholson
11-30-2012 07:34:42
 Re: Farmall A Cutout Relay Question ... in reply to gene bender, 11-30-2012 03:55:54
About 6 of them from retrofitted F series to Bs, Cs and As. All had either direct F to F from the cutout, or the light switch hooked up to the F terminal. I was born in 1949 and by the time I was 9 I was messing with them. (but that puts me at 100 series introduction, so) I have never seen a C or B or other system From the factory. Jim
