TractorLinks.com
Show Parts for Model:
Re: 560D swap
Owen Aaland
11-28-2012 18:40:41
You could just use the crankshaft from the C263 to replace the one in the D282. The combine engine should be new enough that the crankshaft in it was used in both gas and diesel engines.
As far as swapping the engines all the rear parts from the diesel could be used with the gasoline engine. The diesel flywheel will work as long as you also continue to use the diesel starter. The front plate will have to come from another gasoline tractor engine as the combine plate is different because of the hydraulic pump drive on those machines. The front cover will have to be from either a 460 or 560 gas tractor. The front cover attaches to the top side of the frame where the later tractors attached to the inside of the frame. The frame rails are the same for both gas and diesel on the 560. Throttle linkage and air cleaner tubing are also different between gas and diesel.
