cub pto pully
whigg
I have a 47 F cub and the seal is starting to leak on the rear pto shaft. The only problem I have is someone welded it to the shaft. If I drain the diff. will the whole thing come out in one peice shaft and all? Thanks for any help.
you may not need to drain that just take the 8 bolts out that hold the cast piece on and leave the thin plate alone and it should come out may have to pull sideways some to get the piece out of the engager
