Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Farmall H generator will not charge
gene bender
11-28-2012 12:52:27
Change the leads on the ammeter you never know over the yrs what has been changed. With engine off and lites on does it show discharge.
11-28-2012 13:09:10
 Re: Farmall H generator will not charge in reply to gene bender, 11-28-2012 12:52:27
Engine off, lights on, it shows a discharge.
Bob M
11-28-2012 13:41:40
 Re: Farmall H generator will not charge in reply to Darwindo, 11-28-2012 13:09:10
Your test shows the ammeter is wired correctly and is working!
A couple possibilities for the "no charge" condition:
1 - A bad ground at the VR. Try running a wire from the regulator base to the grounded battery post. Check also also the ground jumper between the VR box and the sub-base is still intact.
2 - Loose/slipping generator belt. Check and tighten as required.
