TractorLinks.com
Show Parts for Model:
Re: Is this 200 block repairable
Jim Becker
11-28-2012 12:40:15
Quoting Removed, click Modern View to see Not to mention the value of a Super C wide front end.
As far as the damaged block goes, I would not put big bucks into doing a rebuild on it. However, if you can re-ring it and stick in whatever crank bearing inserts it needs, you can likely put it back together and get quite a lot of use out of it. Just go gently on torquing the head down, use smaller torque increments and make more passes with the torque wrench. We had an A that looked about the same (except the crack went through one of the stud holes!). We used it for years. Somebody may still be using it.
