| Farmall & IHC Tractors Discussion Forum |
Topic: SM Flywheel removal
[Return to Forum]
| Author |
[Modern View]
| Pete_5959
11-28-2012 12:28:38
70.63.206.178
Need to pull flywheel to resurface. Do I need to mark this so it is remounted in the same orientation? What is the best method for removal block of wood/hammer or a puller. Thanks in advance for words of wisdom.........Pete |
[Reply] [No Email] | |
| DeltaRed
11-28-2012 17:42:33
67.6.219.50
Re: SM Flywheel removal in reply to Pete_5959, 11-28-2012 12:28:38
| IIRC,some flywheels are drilled 'off center',so it can only go on one way.The ringgear doesnt need to be removed to surface the flywheel.Since its apart,now is a good time to renew,,rotate,or flip... |
| pete_5959
11-28-2012 14:39:23
70.63.206.178
| Not much to it. I was able to remove by hand and yes it is heavy. The ring gear looks like new. Machine shop says they will have it ready Friday so looks like I will actually start the reassembly Saturday. Finally! |
| CNKS
11-28-2012 14:11:51
216.144.104.128
| There should be a dowel. As stated it is heavy. They usually come right off. A puller for something that size would cost a small fortune. |
| BigTone
11-28-2012 13:48:59
70.192.1.102
| When i took my M flywheel off I put a long 2x4 (one i used was about 3 feet long so I could hold onto it) against the side of the flywheel and gave it a couple of raps with a 3 pound hammer making sure to hit the wood and not the flywheel. I did that on both sides/top and bottom and it finally wiggled off. Be carefull, it weights a ton, you dont want to drop it on your toes. I would also suggest checking the ring gear for wear. May want to change it out while you have it all apart. good luck ~Anthony |
| mkirsch
11-28-2012 12:33:02
64.80.110.75
| Doesn't it have an alignment dowel?
Last flywheel I removed, I just removed the bolts and gave the flywheel a few wiggles. It came right off. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
