Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Is this 200 block repairable
11-28-2012 11:04:55
I wouldn't bat an eye for that price. $200-$250 front wheels weights, $1000 in rear tires. Don't take advice from individuals who tell you there opinion it's worth $500. Those are individuals who want it for nothing! Those day are long gone.
Jim Becker
11-28-2012 12:40:15
 Re: Is this 200 block repairable in reply to W.Brehm, 11-28-2012 11:04:55
Quoting Removed, click Modern View to see Not to mention the value of a Super C wide front end.
As far as the damaged block goes, I would not put big bucks into doing a rebuild on it. However, if you can re-ring it and stick in whatever crank bearing inserts it needs, you can likely put it back together and get quite a lot of use out of it. Just go gently on torquing the head down, use smaller torque increments and make more passes with the torque wrench. We had an A that looked about the same (except the crack went through one of the stud holes!). We used it for years. Somebody may still be using it.
