Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall A Cutout Relay Question ...
Bob M
11-28-2012 10:37:12
To clarify, only a single wire is required - from the generator F post to the light switch field resistor terminal. Nothing is connected to the cutout box F terminal.
gene bender
11-28-2012 20:46:35
 Re: Farmall A Cutout Relay Question ... in reply to Bob M, 11-28-2012 10:37:12
So why did they come from factory with the cut-out hooked to the gen field
Janicholson
11-29-2012 06:38:27
 Re: Farmall A Cutout Relay Question ... in reply to gene bender, 11-28-2012 20:46:35
When no lights were on the tractor, there was no other control for the gen. The cutout had that resistor to ground that allowed the gen to produce just enough that averaged tractor use charged the battery correctly. The third brush allowed a range of farmer selected adjustment to charge more or less. The operator may have had only the mag grounding mechanical pull wire kill switch to control running. Jim
