TractorLinks.com
Show Parts for Model:
Re: Farmall A Cutout Relay Question ...
gene bender
11-28-2012 08:18:52
I have several of them on my As,BNs and Bs all are wired feild on the gen to field on the cut-out and the wire going to the lite sw like they came from the factory. Gen third brush is set for couple amps and hi-charge is around 7 or so they have been that way for many yrs and work just fine. I get 6 or more yrs on the battsat least most of the time i get 8 or better. They bring me tractors from time to time and thats the way i do them also. There is a regulator made for that gen series. The gen 1101423 also takes the same reg. The501,531 gens take a different regulator.
Crazy Horse
11-28-2012 09:03:55
 Re: Farmall A Cutout Relay Question ... in reply to gene bender, 11-28-2012 08:18:52
OK, if I read your post correctly you're saying you run both routes? One from the generator case field post to the cutout box F terminal, and another wire from the generator field post to the switch? Wouldn't a single wire from the generator field post to the switch be doing the same thing by itself? That is .... position #1, field through the switch resistor to ground for low charge rate, and in position #2, field through to ground directly at the switch for full charge?
Bob M
11-28-2012 10:37:12
 Re: Farmall A Cutout Relay Question ... in reply to Crazy Horse, 11-28-2012 09:03:55
To clarify, only a single wire is required - from the generator F post to the light switch field resistor terminal. Nothing is connected to the cutout box F terminal.
gene bender
11-28-2012 20:46:35
 Re: Farmall A Cutout Relay Question ... in reply to Bob M, 11-28-2012 10:37:12
So why did they come from factory with the cut-out hooked to the gen field
Janicholson
11-29-2012 06:38:27
 Re: Farmall A Cutout Relay Question ... in reply to gene bender, 11-28-2012 20:46:35
When no lights were on the tractor, there was no other control for the gen. The cutout had that resistor to ground that allowed the gen to produce just enough that averaged tractor use charged the battery correctly. The third brush allowed a range of farmer selected adjustment to charge more or less. The operator may have had only the mag grounding mechanical pull wire kill switch to control running. Jim
