Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: M Carb problem
11-27-2012 17:54:10
I have run into that problem when using an aftermarket carb rebuild kit. Carb will either leak gas out the bottom of the bowl or won't have gas in the bowl. I've found that replacing the needle valve & seat with a CIH brand usually eliminates the problem. An old IH mechanic was the one that recommended using the CIH needle valve & seat.
11-28-2012 07:32:32
 Re: M Carb problem in reply to soybeanjoe, 11-27-2012 17:54:10
If you clean the new needle valve and seat with aerosol carb cleaner before you install it, you won't have any problems either. GUARANTEED!
