f 400 clutch pedal busing is two piece ?
jim_uny
is the farmall 400 clutch pedal busing two pieces so that grease can go around bushing inside ? ordered part only got one and does not seem correct.
didnt know that they had a bushing. usually have to machine the hole and install a bushing. from factory was no bushing.
I offer a clutch pedal repair service, I bore out your old pedal using a bridgeport mill and I press in two brass bushings and then finish hone the bushing to fit a new shaft. I have three different size bushings depending how wore your pedal is determines which bushing I use. I usually have a two day turn around service. My e-mail is open. Charlie
