Anonymous-0
Hey Guys I have a 656 with a schwartz wide front end on it. I want to put a narrow front end on it. I have one from a 560 and was wondering if they are the same. Also the tractor has pressed steel rims on it.Are they heavy enough to hold the weight of the picker Thanks
It should bolt right up . I took a trashed swartz wide front off of my 560 and put a narrow front from a 656 from a local salvage yard on. Bearings and seals should also be the same .
