Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 400 hydraulic levers
D Slater
11-26-2012 17:59:35
Need to move the sheet metal. Then you can see whats wrong and how to go about it. Probably a pin broke or cam out, or the link to the valve failed or came out of the holes. That outside handle is on a shaft with a lever on the other end that works the left side valve, joined by a pin. Lots of times the hole gets worn in the shaft and the lever untill the pin breaks or falls out.
Btaft
11-26-2012 18:16:30
 Re: 400 hydraulic levers in reply to D Slater, 11-26-2012 17:59:35
D Slater, thanks for the quick response. Last time I posted a question you were quick to respond and right on the money! So I shouldn't have to remove the outside lever, and for future reference, if I do, it unfastens from inside and just slides out? I will look tomorrow and see if I can see where the problem is now that I know where to look, thanks
