TractorLinks.com
Show Parts for Model:
Re: 12 volt conversion
Central Illinois
11-26-2012 17:26:09
I converted mine about 7 years ago. I had the generator rewound to 12V, changed the regulator to 12V, put in a coil from a Kohler 12 h.p. engine with an internal resistor, switched the bulbs to 12V, switched the battery cables to a heavier cable and made the system into a negative ground. Because I switched polarity I reversed the wires on the ammeter and made for sure the coil had the negative side going to the points. Mine finally this last summer had the battery replaced. It has been trouble free. I converted a friends H the same way plus added electronic ignition to it. It starts as soon as the button is pushed.
