Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall M miss on one cylinder, oil seeping from intake
rustred
11-26-2012 07:47:40
ooh is that so? stop assuming.i answered that right off the bat. didnt you read where i said broken piston.your assumptions dont make sense either. your making a big deal out of that wet manifold like its just drowning in oil which is not the case as the pic shows. when you ever get compression checked and tell us then can go to next step. ... my scenario is when you have compression with the head rebuilt that my cure the oil leak your talking about. even just working the tractor in the field under load can cure that ,,, kinda. i have saw lots of these old tractors slober just puttsing around yard with no load and never reach operating temp. so happy compression checking, as i said reading plugs and compression check tell the story so why assume.
scruffyia
11-26-2012 09:57:27
 Re: Farmall M miss on one cylinder, oil seeping from intake in reply to rustred, 11-26-2012 07:47:40
so a broken piston is your scenario where the head doesn't have to come off to fix it the oil leak???
Thanks for you time.
later,
mark
rustred
11-26-2012 12:42:39
 Re: Farmall M miss on one cylinder, oil seeping from intake in reply to scruffyia, 11-26-2012 09:57:27
NO ITS NOT!check your compresion for the forth time.do you know how or understand compression readings, no one here can give you more advise till thats done. forget it your lost on this engine and do not even understand what i am telling you. you just want to argue and not follow direction.
