TractorLinks.com
Show Parts for Model:
Re: H ser.#
D Slater
11-26-2012 04:20:33
Sounds like you're in the dark so probably should explain more. Cast # 6342DH is the engine block for a farmall model A or B tractor. # 8638DE is the casting # for a center housing used on both the above tractors. Most of the B tractors have the engine serial # and chassis # the same if original. Up to serial # 201,000 did. Engine number is stamped in the engine block on a flat surface high on the block, right side. Guessing its a model B since you think it may be a H tractor.
