Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall M miss on one cylinder, oil seeping from intake
scruffyia
11-25-2012 18:39:22
I've thought it over and I'm going to have the head rebuilt. The amount of oil seeping out from the manifold/head gasket and running down the head isn't normal or "good". If that cylinder was firing, it would just be burning quite a bit more oil than it has been.
At one point today I cleaned off the seeped oil, replaced two plug wires, fired it up, shut it down, replaced the other two wires, fired it up, did some tests, then shut it down. In just that few minutes the oil had seeped out again and ran down to the cover below, an inch or two wide shiny seep.
The plug not firing I'd expect to be covered in gas (flooded), not covered in unburnt oil like I mentioned.
so whether it has compression or not, the head has issues and needs some TLC. and the reason for the cylinder not firing will be found as it's being torn down. with it leaking oil so easily out the manifold gasket, it's probably leaking air as well. The manifolds look brittle, so while it's torn down if they as brittle as they look, they'll be replaced as well.
Too bad it didn't do this last spring, it would have been a nice summer project...
thanks,
mark
rustred
11-25-2012 20:48:47
 Re: Farmall M miss on one cylinder, oil seeping from intake in reply to scruffyia, 11-25-2012 18:39:22
well if you where messing with it how come u didnt check compression with the thumb method as i said? telling u what to do and your still guessing.diagnose the problem before teardown. for all we know it may be the valve cover leaking and running down??? may have a broken piston and pumping oil out??? kind or annoying when you give the guy directions to find the problem and he comes back with another story, not attempting to find his problem he asked about.
as i said # 1 is compression check.
