Hayfarmer
Looking at a tractor "project" From pictures it appears to be a stage II super M. Tires and wheels look good, has wide front end and live hydraulics. Looks like it may have been on a loader as it has 3 hydraulic falves on side where the Christmas tree would be. I can't tell if wide front is IH or aftermarket. Kicker is engine is stuck from"water going down exhaust". Part of the problem is there is no way to check other parts with stuck engine. What would be a reasonable value for tractor?
I paid 700 for this m stuck.It worked out all right for me. Kent
"water going down the exhaust" just replaced # 2 sleeve and piston. Somebody foregot to replace the can, water went into # 2 & 3 cyl. Put a flapper on the exhaust pipe.
