TractorLinks.com
Show Parts for Model:
Re: Farmall M miss on one cylinder, oil seeping from intake
rustred
11-25-2012 16:43:29
that oil is due to cyl. not firing as i suggested.you have a bad valve, no compression on that cyl. that cyl's valves has nothing to do with the other cyl's running. i am leaning to the burnt valve cause they cant be stuck if you say you use the tractor. so check compression then tell us what u find. also can hear a burnt exhaust valve, and thats the ones that burn first. i would not even worry about the compression tester. just hold your thumb over hole while cranking cause there would be no compression to even blow it off. then you know its tear down time in a hurry.
