Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: H ser.#
marvin f harkins sr
11-25-2012 15:15:54
the only # on r/s is behind oil filter 6342 D H. if there is a tag on l/s, cluth houseing it is missing
D Slater
11-25-2012 15:34:55
 Re: H ser.# in reply to marvin f harkins sr, 11-25-2012 15:15:54
A or a B tractor.B if narrow front. Serial may be on the seat support. Lot of serial number tags are missing. Some tractors used the same engine serial number as the chassis. Up to a serial number break.
D Slater
11-26-2012 04:20:33
 Re: H ser.# in reply to D Slater, 11-25-2012 15:34:55
Sounds like you're in the dark so probably should explain more. Cast # 6342DH is the engine block for a farmall model A or B tractor. # 8638DE is the casting # for a center housing used on both the above tractors. Most of the B tractors have the engine serial # and chassis # the same if original. Up to serial # 201,000 did. Engine number is stamped in the engine block on a flat surface high on the block, right side. Guessing its a model B since you think it may be a H tractor.
