| Farmall & IHC Tractors Discussion Forum |
Topic: Backfire?
[Return to Forum]
| Author |
[Modern View]
| Lucid
11-25-2012 14:34:01
75.197.242.19
Was using the disk on some previously plowed ground. Did a little bit in first, then started in 2nd. A loud pop happened soon after on the left side of the tractor. Scared the snot out of me! Made my left ear ring too. Think I even saw a quick flash similar to a firecracker going off.
Nothing seemed leaking, so I continued on for another hour. Finished up, pulled on hard ground, and shifted into 4th gear (road gear). Tractor wouldn't go, acted like it while it was jerking forward, then died. Started tractor and it backfired again.
What is going on with my Farmall 200? |
| PretendFarmer
11-26-2012 18:13:46
108.227.198.61
Re: Backfire? in reply to gene bender, 11-25-2012 14:34:01
| Quoting Removed, click Modern View to see
No matter what, looks like you gotta get that valve cover off and take a look. Then adjust valves. |
| rhtx55
11-26-2012 16:20:32
68.185.207.25
Re: Backfire? in reply to Lucid, 11-25-2012 14:34:01
| Pull the valve cover, sounds like a push rod jumped off the rocker. |
| Lucid
11-26-2012 13:13:56
75.197.150.160
| I am wanting to do an overhaul, now looks sooner than later. The plug conditions are; (1-4) carbon/sooty, light grey/tan soot, oily, & clean. |
| mkirsch
11-26-2012 12:32:22
64.80.110.74
| I'll bet if you post a video of the tractor running, it doesn't sound good. That #1 cylinder can't possibly be firing, and #2 isn't firing much. #3 and #4 are barely adequate to fire. In fact I'm surprised you can get the tractor to start without towing it and spinning the bejeezus out of the engine.
Your tractor must sound like an old 2-cylinder JD, pop-pop, pop-pop. It's supposed to sound like a sewing machine, nice and smooth.
On a 200, you can SEE the pistons reach TDC from the spark plug holes. Shine a light down in there and see if #1 is moving up and down.
Definitely going to have to dig into the engine to find what's wrong. |
| Lucid
11-26-2012 10:45:22
75.197.253.31
| Just finished the compression test. #1 I redid a few times as I wasn't sure if I was fully seated or not. From #1-#4; 8, 45, 60, & 70. Also checked the distributor and the cap had some oil in it. I cleaned it out with a shop rag. Not looking good.. |
| JRSutton
11-26-2012 11:09:40
75.130.109.233
Re: Backfire? in reply to Lucid, 11-26-2012 10:45:22
| | 8? That's definitely not good. Have you adjusted your valves yet? |
| Lucid
11-26-2012 11:36:55
75.197.43.234
Re: Backfire? in reply to JRSutton, 11-26-2012 11:09:40
The first try the gauge didnt even move. Unscrewed the gauge and retried it. It moved almost to the first bar on the gauge, 3rd go round was about the same. :/ Possible the #1 piston is stuck?
After I did my work, I was going to change the oil. And drop the pan to clean the oil pump etc. Then adjust the valves. |
| JRSutton
11-26-2012 13:23:20
75.130.109.233
Re: Backfire? in reply to Lucid, 11-26-2012 11:36:55
| My first guess (and/or hope) would be a stuck or out of adjustment valve. |
| PretendFarmer
11-26-2012 11:45:33
192.249.47.207
| Im not sure how a piston could be stuck and have it run.
In my opinion, you should adjust the valves. You might be amazed at what that would do. If you have never done it, then its a good time to start.
I did mine with a .020" shim cold. Hot was .014" I think.
Its easy.
If you dont know how to adjust them, ask and I will give you step by step.
After you adjust, leave the valve cover off and run it. You(or at least I can) can tell if there is something out of order such as a valve not closing properly.
This post was edited by PretendFarmer at 11:47:04 11/26/12. |
| JRSutton
11-26-2012 07:35:46
75.130.109.233
| | Most likely not getting enough gas through the carb. Sometimes they'll starve when you push them to work harder. You can try richening it up a bit to see if that helps. It probably will. If not - I'd give the carb a good cleaning and be sure you're getting good gas flow to the carb. |
| Lucid
11-25-2012 15:45:24
75.243.145.62
| Just got a compression gauge last week. Will start there tomorrow mourning. Thanks. |
| glennster
11-25-2012 14:46:27
99.90.9.201
| lean fuel mixture can cause backfire-ing, also, ignition and valve issues. first stop would be a compression test to see if all the cylinders are within 10 percent compression. then check fuel delivery, then check distributor, possibly worn bushings causing point gap to vary. could be a cracked cap or moisture in the distributor too. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
