TractorLinks.com
Show Parts for Model:
Re: Gear oil for a Super C
old
11-22-2012 07:31:51
What I do when I have a tractor that does not use the same oil for hyds as the rear/trans I use the 85W-140 and then add some graphite if I can find it to the oil and that helps a lot more then any other snake oil like that Lucas stuff
Duner Wi
11-22-2012 18:38:50
 Re: Gear oil for a Super C in reply to old, 11-22-2012 07:31:51
John Deere store sells powdered graphite in a fair sized bottle for planter plate lube. That might be what you want. Not expensive the last time I bought some.
old
11-23-2012 08:42:05
 Re: Gear oil for a Super C in reply to Duner Wi, 11-22-2012 18:38:50
Next time I am around a JD dealer I may have to stop in and check it out. Sad thing is the closest one is some 30 or so miles from me. Doing the graphite thing was an old hot rodders trick and you put it in the rear end and transmission if it was stick shift and in theory it reduced friction so you got butter MPG and faster times on the track
