TractorLinks.com
Show Parts for Model:
Re: Gear oil for a Super C
gene bender
11-22-2012 07:31:27
I wou7ld drain and then fill with 4 gal of diesel drive around a little then drain and refill with 150wt sure wont hurt. The straight cut gears can sure be noisy sometimes. I have found when replacing the input seal i also replace the bearing and most of the time it sure quiets the gear noise just makes sense if the input shaft has play the main shaft will transmit noise to other gears.
