Farmall 230 bottom grill pan.
I'm looking for a bottom grill pan to replace one that is no longer there on my 230. What models can I rob the pan off of? I'm looking for a grill that I can cut the bottom pan off of and put on my 230 grill. What I need to know can the pan off an A B or C be adapted to fit. Thanks Larry
Larry
I would think, it would have to be off a 100,130, 200 or 230. The C grill is shorter than a super C grill due to the taller radiator and that is the same as the 200 and 230. The hand crank hole might be the other problem from a C grill, The pan is shorter.
They have the "grill bottom panel" on this site. Not sure if its what your looking for. $196.00
Click the link. You might have to call them to see if it what you need.
Tracy
Untitled URL Link
oem tractor parts has new replacement bottoms for 230 grills, I have gotten one for mine. alot less trouble than cutting the spot welds off an old grill. only c super c, 200, or 230 will work. super a, 100,and 130 are different.
