Super M Progress
Pete_5959
Well I finally got the transmission reassembled with new bearings and replacement gears(3) that had teeth missing. Local IH dealer had pressure plate, disc, and both bearings in stock $240.00 for the group and plan on picking up Friday. Going to pull the flywheel tomorrow and have it resurfaced. While I have this apart is there anything else I should take a look at that has been known to cause issues? I see no fluid leakage on rear seal. Thank you for any info/advice.
Looks like you have it under control to me.gears,bearings,and seals are just about it inside the gear case.
I am sure you took care of the bearings and seals at the brake pinion shafts?
