Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
300 want start
susan a
11-21-2012 13:33:12
i have a 1956 farmall 300 and she want even turn over put a new battery in it and tryed to start it and nothing happen then we tryed to pull start it and it still didnt even turn over we done no if the key swicth is no good or is the starter it self thanks for any help
El Toro
11-22-2012 04:21:08
 Re: 300 want start in reply to susan a, 11-21-2012 13:33:12
If the starter isn't jammed pull all the sparkplugs and see if any liquid is on top of the pistons. Borrow a borescope light and look in all the cylinders for rust. Since it won't turn over your engine may be seized from rust. Hal
Janicholson
11-21-2012 19:07:21
If you find that the starter was jammed, a replacement starter drive is available that is much better than the old style. The main difference is the replacement of the drive spring with a better cushion based pinion, and smaller spring.
How did the other information given you on prior posts work out? Letting us know what fixed your tractor's problems is important to all on the forum. Jim
Janicholson
11-21-2012 19:31:17
 Re: 300 want start in reply to Janicholson, 11-21-2012 19:07:21
If you accidentally left the fuel on, and it filled one or more cylinders with fuel it will not allow the engine to turn. Check the oil for gasoline smell.
Also do not pull start a locked engine it is a sure way to bend a connecting rod, or break a crankshaft.
Jim
susan a
11-22-2012 09:03:03
 Re: 300 want start in reply to Janicholson, 11-21-2012 19:31:17
the engines not locked up and i was just runiing it about a week ago and i went to start it and it did even make a sound that it wanted to turn over i tryed the starter but it didnt work but i will try it again to
ken house
11-21-2012 17:13:22
have you ran this tractor lately? is this tractor new to you?
gene bender
11-21-2012 14:28:17
Yup the starter drive is locked to the flywheel just do as other post said loosen the bolts on the starter and wiggle the starter the bendix should release. Check all batt connections as a weak voltage can cause the starter to lockup pretty easy mite need a new Bendix.
susan a
11-21-2012 15:13:33
 Re: 300 want start in reply to gene bender, 11-21-2012 14:28:17
would you have to take the tractor apart to fix it just wondering
Hugh McKinney
11-21-2012 17:10:12
 Re: 300 want start in reply to susan a, 11-21-2012 15:13:33
As they said, all that is required is to loosen the bolts, probably three at the most, that hold the starter on. The tractor would not need taking apart.
hayfarmer
11-21-2012 13:38:22
If when you tried to pull start it it wouldn't turn over(wheels slid) something must be locked up . Might try loostening starter to see if stuck in flywheel.
