TractorLinks.com
Show Parts for Model:
Re: Fast Hitch Post Hole Digger
Larry Hardesty
11-20-2012 21:30:17
What brand is it?
Larry
Too Far Gone
11-21-2012 04:49:09
 Re: Fast Hitch Post Hole Digger in reply to Larry Hardesty, 11-20-2012 21:30:17
I dont have a clue what kind,but it works good,and gearbox is very heavy.Its a diggin little fool,and better than any P.O.S farm store digger Ive ever had.If IH ever put out their own,Id guess it was that brand.I know anything and everything gets painted and has for a long time,but it sure had very old red paint.It was used ona 606 for many years with filler bars.
farmallhal
11-21-2012 06:16:54
 Re: Fast Hitch Post Hole Digger in reply to Too Far Gone, 11-21-2012 04:49:09
I believe yours is an Ottawa Farm Chief or Super Farm Chief as I have one that is very similiar which still has a readable decal. The earlier ones were made in Ottawa, Kansas until the owner of the company died and then the company was purchased by Comfort Engineering in Kansas City and reloacted to one of their plants in Holden, Missouri. The change in ownership and production facilities changed in the early 1950's I believe. They are a very good rugged auger and I have one I use on my fast hitch Super C with excellent results. Replacement parts to my knowledge are not available from any source so it's off to a machine shop if anything breaks, Hal.
Too Far Gone
11-21-2012 06:47:24
 Re: Fast Hitch Post Hole Digger in reply to farmallhal, 11-21-2012 06:16:54
Is yours curved downward like mine,or is it just bent? Ive been thinking of straightening the arms,because it drags some even with the drawbar pitched,but it works fine.
farmallhal
11-21-2012 09:02:49
 Re: Fast Hitch Post Hole Digger in reply to Too Far Gone, 11-21-2012 06:47:24
Your mounting arms are somewhat different then mine and the way they were sold was with the gearbox, PTO shaft and other items that make the basic unit as one part. You then select the tractor mounting kit depending on what make and model of tractor you want to mount on. Mine is a fast hitch model for a Super C and the arms are bent up about 2 feet back from where they insert into the fast hitch. The gearbox is what really makes it look like the Ottawa to me. The gearbox should have a round cast hole where a long handle inserts and I believe held in place with a set screw. That handle is used by the tractor operator to tilt the auger during transport and also to position it when drilling a post hole. You might have a tractor mounting kit on yours for something other then the tractor you have it presently mounted on and might have been modified some time ago by a PO. Good luck and they are certainly a good unit, Hal.
P.S. I live over by Rolla, Missouri and have quite a bit of literature on these augers I would share with you if you are over this direction in your travels.
Too Far Gone
11-22-2012 07:27:47
 Re: Fast Hitch Post Hole Digger in reply to farmallhal, 11-21-2012 09:02:49
This sucker sure dont have a hole to mount a handle or any place where a set screw would go.Wish it did.That'd be kinda handy at times.Ive dug several holes with it since I took that picture.My front seal leaks,but Im pretty confident my lil part store can match the seal.Ive gotta make a shot over to St Louie next month.Its a shame I wont get closer to you,or Id visit about these old things awhile.Sis-in-law is due to hatch a lil girl in December over there.
Too Far Gone
11-21-2012 06:43:49
Heck Hal,Im used to machine shop repairs.I also figure if it ever shells that another head will mount in there real easy,and this auger will fit any 2 inch round shaft with a hole through it.Thanks for all that info.I live near Richmond,Mo,and I think its pretty neat to find it was made close to home.
