Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: wide front shimmy
[Show Entire Topic]  [Return to Forum]
Janicholson
11-20-2012 18:09:16
96.24.99.126
Yes. Lift the tires off the ground one at a time. Spin the tire and use a nail or prick punch to scribe an accurate line on the tread. (requires a steady rest, like a couple of concrete blocks to hold the scribe.)
Shake and wiggle the tire and spindle to find loose spindle or wheel bearings. Spindle bearings allow the vertical shaft to move in the spindle tube
Now lower it back on the ground and drive it up gently against a 2X4 laid on the ground so both wheels are pushed rearward a little. Now measure that front to rear difference. using the scribe marks. It should be about 3/16 to 1/4" If more adjust the tierods to make it so.
Now put the 2X4 behind the tires. back gently into it. Measure again. if the rear are more than about 1/8 inch wider in the rear than front with push on them from the board, there is too much slop. Either tierods, or spindles are worn. Jim
[Reply]   [No Email]
David G
11-20-2012 19:54:07
205.215.206.18
 Re: wide front shimmy in reply to Janicholson, 11-20-2012 18:09:16
Jim, that is exactly how my dad taught me to do that 40 years ago. I can still remember the lines scribed on the tires.
[Reply]  [No Email]
blunted
11-20-2012 19:26:37
208.126.138.141
so, in the houseing thats the bearings are in, do these have to be pressed out or is it simple? thanks
[Reply]  [No Email]
Janicholson
11-20-2012 21:27:38
96.24.99.126
 Re: wide front shimmy in reply to blunted, 11-20-2012 19:26:37
Spindle bearings must be pressed in and out, not a big deal because the cylindrical nature of the tube makes use of a threaded rod easy. Jim
[Reply]  [No Email]
blunted
11-20-2012 19:22:43
208.126.138.141
thanks, jim
[Reply]  [No Email]
blunted
11-20-2012 18:41:17
208.126.138.141
without doing that, it sounds about rite. just repacked the wheal bearins,. noticed the shafts in the axle extetions has slpo up and down. could that also mean bearings are bad? or you need to take the tierod donw more on the shaft?
[Reply]  [No Email]
DeltaRed
11-20-2012 18:48:26
67.6.219.50
 Re: wide front shimmy in reply to blunted, 11-20-2012 18:41:17
The 'up/down' slop will cause the shimmy.The excessive 'toe-in' preobably wont either.that will just cause the front tires to wear REALLY FAST.Check the 'componets' for wear.Loose/slop mean "shimmy"
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
