TractorLinks.com
Show Parts for Model:
300 Utility hyd res.
bkpigs
11-20-2012 17:50:41
I am going to split Dad's hyd resevoiron his 300 utility. I am not seeing a seal for the two halves of the resevoir. Am I missing something? I want to replace the fluid and clean the filter.
D Slater
11-21-2012 05:19:55
 Re: 300 Utility hyd res. in reply to bkpigs, 11-20-2012 17:50:41
Gasket 361875R1.
bkpigs
11-24-2012 17:05:25
 Re: 300 Utility hyd res. in reply to D Slater, 11-21-2012 05:19:55
thank you!!
Janicholson
11-20-2012 18:10:31
Use a thin coat of blue RTV on clean surfaces to seal it. Jim
bkpigs
11-20-2012 18:48:39
 Re: 300 Utility hyd res. in reply to Janicholson, 11-20-2012 18:10:31
I do have another question. What is the difference between the blue and black silicon? I don't have any blue to compare the packages.
Janicholson
11-20-2012 19:20:41
 Re: 300 Utility hyd res. in reply to bkpigs, 11-20-2012 18:48:39
The black cures a little slower, the black is a little more oil resistent. but I feel it will make no difference which you use, it will do the job. Jim
bkpigs
11-20-2012 18:42:46
That is what my fall back plan is. Thanks!
504
11-20-2012 20:18:05
 Re: 300 Utility hyd res. in reply to bkpigs, 11-20-2012 18:42:46
remember any RTV on the inside of the housing will wind up in the hyd pump sooner or later.
