TractorLinks.com
Show Parts for Model:
how to shine plow mold boards
susan a
11-20-2012 15:46:17
how do you you shine old rusty and dirty plow moldboards to be nice and shiney?
dhermesc
11-21-2012 05:44:16
 Re: how to shine plow mold boards in reply to susan a, 11-20-2012 15:46:17
Plow a few acres with them. When you park them for the winter coat them with old engine oil.
MeanGene1
11-20-2012 20:43:41
 Re: how to shine plow mold boards in reply to charlie M, 11-20-2012 15:46:17
At 11, the one time only that I forgot to grease the boards when done in the spring, and gramps trusted me to do it, as I had been trained. Come time to fall plow, and yours truly got handed the 7" Sioux grinder to scour them off
gene bender
11-20-2012 20:21:11
When you get them ready to plow do not plow deep as they just mite not scour at all the deeper you go the more they will not want to scour start shallow then little at a time going deeper.
old
11-20-2012 19:01:31
Simple go out the do what they where made to do and plow up some ground and when done it will be nice and will shine
IH fan
11-20-2012 18:44:24
 Re: how to shine plow mold boards in reply to mattwillson, 11-20-2012 15:46:17
Plow a couple acres of sandy soil. Then coat with grease and store inside.
FBH44
11-20-2012 16:46:55
I plow mine, then paint them with rustoleum red primer, and store them out of the weather. Next time they shine right up in a few furrows.
randy hall
11-20-2012 16:29:43
the old fashioned way is to rub the moldboards with a soft brick. not much fun.
David G
11-20-2012 16:17:22
I got mine sandblasted, then painted with plow paint to keep it from rusting over the winter. The sand blast finish polished right up while using it, then painted it again.
Greg K
11-20-2012 16:02:21
A 4" grinder with a flapper disc about 80 grit works real well to get you close, then using it will finish it up nicely. As was already mentioned after they are cleaned, keep them that way with paint or grease.
johnpop1
11-20-2012 15:58:58
You could do as suggested, but that could take quite a while (depending on your soil type). If you have access to a sand bank or shale bed, you could try pretending to plow the shale or sand. This will clean the moldboards quite well. Another way is to take an angle grinder with a coarse polishing wheel to the rust. After the rust is gone the plow should work quite well. After use, always oil the moldboards or paint them to keep the rust away until next season. In the northeast, moldboard plowing is the way farming is done.
rustred
11-20-2012 15:50:48
best way i kow of is put it to work. they will get so shiney you will see yourself in them. but you need to always stop at each end of field and give them a rap with hammer as the dirt sticks to the rust till they get shiney.
Mark W.
11-20-2012 15:48:24
Use them.
