TractorLinks.com
Show Parts for Model:
Re: Water pump removal
D Slater
11-20-2012 14:29:46
If the lower radiator hose at the radiator end is going to be removed some will be there even if drained. 5 gallons should be below the pump level and can't be much left in the system. If you can get in there to remove the drive lug from the impeller shaft you can install the drive lugs and springs without removing the pump.
rustred
11-20-2012 14:54:12
 Re: Water pump removal in reply to D Slater, 11-20-2012 14:29:46
water pump definitly can stay on. once rad is off you have wide open space to work in. if it was mine i would be looking to get it done without removing rad either, but shroud may be in the way.
