Farmall 340 weights?
With your fronts dished in or out if a row-crop or with a wide front you should be able to double-up on the weights if you wish; you know it will just take longer bolts. Those row-crops get light headed if something in to your backside. Enjoy your 340
Just thought I would peek at the Operator's Manual
"...includes...weights and four 1/2" NC x 2 inch bolts, nuts, lock washers and plain washers ...second set...using four 1/2 NC x 4 inch bolts...
