Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Need Help Removing H Radiator
[Return to Forum]
dstates
11-17-2012 13:43:17
173.18.213.205
So I'm trying to remove the fan and waterpump from my '52 H, but it doesn't come out like a video I saw of an M waterpump being removed(http://www.youtube.com/watch?v=B2tmR7Zmyhk). Even with the radiator rocked forward there isn't room to get it out. So it looks like I need to remove the radiator (which I was thinking about doing soon anyway). My question is... how does the steering shaft come out? Does it come out from the front? Any tips would be greatly appreciated.
Thanks!
[Reply]   [No Email]
dstates
11-17-2012 15:41:54
173.18.213.205
 Re: Need Help Removing H Radiator in reply to dstates, 11-17-2012 13:43:17
Thanks for the help guys... I decided to go ahead and start taking stuff apart. I ended up doing just as Zach suggested except instead of turning the wheel I turned the castle nut at the front and it came right apart and out.
I was able to get the radiator off as well, only problem is one of the radiator mounting studs broke off in the radiator. Nothing like making more work for myself. I think while I have the radiator off I'll send it to a shop and get it cleaned up.
Thanks!
[Reply]  [No Email]
GordoSD
11-19-2012 19:23:05
64.33.250.162
 Re: Need Help Removing H Radiator in reply to dstates, 11-17-2012 15:41:54
Also use your big compressor and a blow gun and spend about 30 minutes blowing 30 years of dust out of it. Do both sides. Geck the stat also. New fan belt when assembling and you have a new cooling system.
[Reply]  [No Email]
Janicholson
11-17-2012 14:15:47
199.17.6.27
The shaft detaches at its rearward end, then the front big plug comes out of the steering box. (clean the shaft if cruddy) then take it out the front. It will screw out for the first 3 inches or so. Jim
[Reply]  [No Email]
kevinj54
11-17-2012 14:15:03
50.36.191.42
 Re: Need Help Removing H Radiator in reply to Kyrock, 11-17-2012 13:43:17
Shaft comes out the front
[Reply]  [No Email]
Zachary Hoyt
11-17-2012 14:14:16
184.12.71.16
To remove the radiator you must remove the grill and on the
wishbone shaped casting at the front end you will see a large pipe
cap which you unscrew with a large wrench. Then you will need to
remove the bolt that holds the horizontal steering shaft onto the
sloped steering shaft and turn the steering wheel to the right. The
horizontal shaft will come out of the hole where the pipe cap was
and once the shafts are separated you will need to pop the
woodruff key out of the horizontal shaft and then the shaft will
slide right out.
Zach
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
