hand crank?
Anonymous-0
Could anyone tell me if the starting cranks were the same for the F-series tractors and the farmall H and M? I know that some were longer for the wide front axle. Mostly wondering if the slot in the end for the starting pin coming out of the bolster was in line with the bend in the handle or was 90 degrees off? Have some that are both ways but not sure if they have been modified or not. Thanks, Mike
you would think thay would be straite, if im getting you rite. i know my a has the crank, but is bigger in diamater for the balster in front of my sc..
I have some cranks around hear that are to small ( hole in the end) to fit my f20 i though that thay were for the m or h . Bob
I can give an answer that works!!
When put on the crank drive, and pushed in to engage the crank, the handle of the crank should be at the bottom, or 15 to 20 degrees clockwise from bottom. (assuming the engine was shutoff and allowed to stop naturally) inline 4 cylinder engines stop with the pistons about 1/2 way in the bores. Pulling up is the only safe (ish) way of cranking, and if the pin placement was incorrect, the handle would be in an unsafe position. Jim
