Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1566 won't start, even with ether
Allan In NE
11-17-2012 02:31:29
Okay,
Then, you've got engine troubles; more than likely low compression, since the engine was stuck. That is to say, the engine may now be free but perhaps all of the rings aren't.
If this were my tractor, I shoot a can of GM's Top Engine Cleaner in the intake while cranking it over. Slop it down real good and let it soak overnight to see if the thing loosens up enough to at least get it started.
Also, do you have good engine cranking speed? No, ya can't pull 'em to start.
Another thought; perhaps you're up against the original reason it was parked to start with?
Just thinkin' out loud here,
Allan
Jasondr
11-17-2012 06:22:49
 Re: 1566 won't start, even with ether in reply to Allan In NE, 11-17-2012 02:31:29
First thanks for all your time thinking about this thing, i really appreciate it. We had penetrating oil down the injector holes to get it loosened up then cranked it over to blow it out, then squirted motor oil to lube and help with compression. It cranks over good for about five seconds then slows way down, one week battery I'm guessing because we have it on a big battery charger , new starter. I guess it ran good when it was parked. They just used it for tillage and all the land was into hay.
