TractorLinks.com
Show Parts for Model:
Re: Sleeve Removal Puck Sizes
El Toro
11-16-2012 10:22:26
You may also need the measure the block so the outside diameter of your pucks will clear the block. If the bore diameter on the sleeve is 3.00" at the seal under cut the puck to 2.990" to 2.987". On the 3.125" bore undercut puck to 3.115" to 3.113" and on the 3.1875 bore undercut to 3.1865-3.1863". Since these sleeves are probably worn, a .010" undercut on the puck should fit easily into the bore of your worn sleeve. Hal
equeen
11-16-2012 14:59:05
 Re: Sleeve Removal Puck Sizes in reply to El Toro, 11-16-2012 10:22:26
Thanks, El Toro.
Man is that 3.25 bore a thin-walled sleeve!
