Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: axel bearings on M farmall
sflem849
11-16-2012 04:28:51
Slater, what do you replace them with? I guess the question is shielded or unshielded?
D Slater
11-16-2012 05:17:15
 Re: axel bearings on M farmall in reply to sflem849, 11-16-2012 04:28:51
Don't really know the best answer to that. When IH went to the unshielded bearings and no grease fittings hydraulic transmission oil was used with oil return to the transmission a little different than early models. Don't know if heavy gear oil tractors would make a difference or not. Then you find some with the shield unattached to the bearing at removal. Due to overgreasing or other. You can find unshielded bearings installed later along with axle caps with no grease fittings on M tractors on up. Shielded with the right amount of grease at the correct intervales may be extra insurance if the tractor is operated with one side high for long periods. For incorrect greasing the open is probably better. When the open bearing is installed with grease fitting axle caps, plug the fitting holes.
Copyright © 1997-2015 Yesterday's Tractor Co.
