Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: DEATH WOBBLE IH B414??
[Return to Forum]
THE HAPPY FARMER
11-16-2012 03:53:28
67.206.183.89
I HAVE AIH B414 TRACTOR, JUST WENT THROUGH THE STEERING GEAR COMPLETLY.(EVERTHING IN GEARBOX IS NEW EXCEPT FOR THE HOUSING IT"S SELF?? HAVE A DEATH WOBBLE, WHEN I HIT THE PAVEMENT! ANY IDEAS? WHEEL BRGS? ALIGNMENT? AT A LOSS RIGHT NOW, GOING TO GO THROUGH WHEEL BRGS AND GRASE EVERYTHING? NOT SURE IT"S GOING TO HELP?? AT WITTS END! LOL
[Reply]   [No Email]
Fritz Maurer
11-16-2012 04:59:35
216.137.138.146
 Re: DEATH WOBBLE IH B414?? in reply to THE HAPPY FARMER, 11-16-2012 03:53:28
Pitman arm splines worn or damaged or the nut is loose
[Reply]  [No Email]
THE HAPPY FARMER
11-17-2012 04:51:13
67.206.184.92
 Re: DEATH WOBBLE IH B414?? in reply to Fritz Maurer, 11-16-2012 04:59:35
REPLACED SECTOR SHAFT WITH NEW, PITMAN ARM IS TIGHT AND NO PLAY THERE? MIKE B.
[Reply]  [No Email]
THE HAPPY FARMER
11-17-2012 04:40:55
67.206.184.92
THE STEERING GEAR HAS ALL NEW PARTS, AND HAS BEEN SET UP PROPERLY THE ONLY USED PART IS THE CASE.??
[Reply]  [No Email]
Michael Soldan
11-16-2012 04:27:08
24.235.36.51
Check the verticle alaignment of the axle,in other words are the spindles absolutely straight up and down.The tube in the from axle could have bent or flexed enough to let the spindles slope back slighty,putting more weight and stress on them making steering skewed. Also check for a bent rim,identical tires on both sides,identical air pressure
[Reply]  [No Email]
THE HAPPY FARMER
11-17-2012 04:55:44
67.206.184.92
 Re: DEATH WOBBLE IH B414?? in reply to Michael Soldan, 11-16-2012 04:27:08
YUP THAT'S WHERE I'M HEADED NEXT, GOING TO CHECK ALIGNMENT, AND CHECK EVERYTHING UP FRONT. STEERING GEAR IS GOOD, SO IT HAS TO BE UP FRONT SOMEWHERE! THANKS MIKE B.
[Reply]  [No Email]
MJ in the UK
11-16-2012 04:25:04
213.122.92.168
Got a B414 with the same problem after I replaced all the track rod ball joints, king pin bushes and rebuilt the steering box. Put new axle centre pin and bushes in and cured the problem. MJ
[Reply]  [No Email]
THE HAPPY FARMER
11-17-2012 04:45:26
67.206.184.92
 Re: DEATH WOBBLE IH B414?? in reply to MJ in the UK, 11-16-2012 04:25:04
YES I'M HEADED THERE NEXT, JUST OVERHAULDER THE STEERING GEAR AND IT'D PERFECT! HEADED FOR THE FRONT END NEXT?? THOUGHT I MIGHT TRY TO RESET THE TOE? SEE IF I CAN MAYBE CURE IT THAT WAY?? IF NOT I'LL GO THROUGH THE WHOLE FRONT HALF! MIKE B.
[Reply]  [No Email]
Michael Soldan
11-16-2012 10:26:24
24.235.36.51
Yes,my B250 got hard to steer and it was the front axle ,worn bolt holes allowed the tube to turn slightly putting the tractor weight ahead of the center of the tires,could hardly turn the steering wheel. I aligned it up,put in new bolts,tightened everything up and all is well.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
