Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Standard BLOCK Bore C113 and C123
[Return to Forum]
equeen
11-15-2012 20:34:27
209.102.248.236
Can anyone please advise of the factory block bore for engines:
C-113
C-123
Also, was block number 354898R1 bored for C-113 and the same block factory bored for C-123?
Thanks.
[Reply]   [No Email]
CNKS
11-16-2012 19:51:44
216.144.104.128
 Re: Standard BLOCK Bore C113 and C123 in reply to equeen, 11-15-2012 20:34:27
The 898 block was initially sleeved with thicker sleeves to give only 113 cu in until the Super A1 and Super C appeared. Then the cu in went to 123. The 898 blocks in the 113 and 123 were identical and had identical bores, only the sleeves were different. The current engine kits have sleeves that allow 134 cu in without increasing the size of the original bore. The 898 block is not to be confused with the original C113 block, which will accept later sleeves no larger than those giving 123 cu in without boring.
[Reply]  [No Email]
teddy52food
11-16-2012 06:37:15
184.94.175.179
898 block is 123 or the larger of the 2.
[Reply]  [No Email]
gene bender
11-16-2012 04:06:49
207.177.56.85
You need the part # on the block as later blocks would accecpt 3 1/4 sleeves olser blocks were the same with the exception of having a place for the hy pump. You need to measure the bottom where the sleeve seats to see which block you have it will also have the place for the hy pump. Side note a 113 block will take larger sleeves making it 123cu in.
[Reply]  [No Email]
stumper
11-15-2012 22:56:41
24.247.104.181
C-113 is 3" and the c-123 is 3 1/8" of witch both these engines have wet sleeves in them , stumper
[Reply]  [No Email]
stumper
11-15-2012 22:52:23
24.247.104.181
C-113 is 3" and the c-123 is 3 1/8" , stumper
[Reply]  [No Email]
ShaggyM
11-16-2012 03:09:20
173.17.86.110
 Re: Standard BLOCK Bore C113 and C123 in reply to stumper, 11-15-2012 22:52:23
Both have wet sleeve's.
Some C 123's also had 3 in bore.
You can put a 3 1/8 bore in a C 113
and a 3 1/4 bore in a C123
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
