Farmall 300 Fast hitch cylinder removal
Dean Olson
I have a late 55 Farmall 300 with a newer 350 style fast hitch. The cylinder needs to be removed to be rebuilt as it's leaking.
It has a depth control rod on the right side of the upper pin.
It's not obvious to me how it comes apart.
How do you remove that upper pin?
Hard to see in the picture but i there a spring loaded pin that is perpendicular to the pin in question? If so push it in and drive the other pin out.
There is a roll pin through the cylinder shaft end eye and the pin. Roll pin comes out then the big pin. Lower pin should be easy to figure out or like the other poster said.
