Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: moisture coming out of exhaust on startup
PretendFarmer
11-15-2012 06:17:47
The engine has an Antifreeze and water 50/50 mix in it.
It appears to only be for the first few minutes on startup. After that there is no moisture coming out. I cannot tell if it is just water, or if its the engine coolant.
I will retorque the head prior to the next startup as a precaution.
mike1972chev
11-15-2012 07:09:17
 Re: moisture coming out of exhaust on startup in reply to PretendFarmer, 11-15-2012 06:17:47
If it IS leaking anti freeze in to the combustion chambers it will have a "sweet" smell at the exaust,the liquid will also have a sweet taste on your tounge(Although I am not recommending doing so!!! :)
If it IS clearing up after running,I doubt anything is wrong other than condensation.
Like others said,check all your spark plugs after running it and leaving it set all night.THAT will tell you a story.Watch for coolant loss at the radiator as well.
I would STILL re torq gasket even if it all checks out ok just because it is a good idea.
