Fire Crater Pistons
I bought a H farmall that was stuck and after getting it loose I decided to tear it down and found #1 cylinder had water in it and has pitted th cyl. wall top 1 and 1/2" This engine had almost no hours on rebuild, with oversize fire crater step pistons. Question can I buy 1 sleeve and piston or one sleeve by itself? Piston is fine rings are ok just don't want to try with pitted sleeve Is there a dealer that sells fire crater sleeves/pistons that i might talk to about this? Any Help would be greatly appreciated Thanks Marti
Try here at Yesterdays Tractors under tractor parts. You can buy one sleeve. I have been pleased with parts from here, and delivery was very fast. Ordered a carb early one Thursday morning, had it in my hand Saturday afternoon!
Best Regards,
Charlie
I bought a stuck 300 in May and replaced one piston and sleeve that were badly damaged from water. it is running fine up to now, I have only been running it since August and have put maybe 30 hours on it so far. If the piston and rings are good I would just get a new or good used sleeve and try it.
Zach
