| Farmall & IHC Tractors Discussion Forum |
Topic: 806 TA
[Return to Forum]
| Author |
[Modern View]
| farmallzach
11-13-2012 16:51:25
70.194.5.91
I just bought an 806 gas yesterday. I was just looking for some kind of planting tractor. I bought it knowing that the TA was out on the low side. Now that I got it home, driving it up and down some hills it seems to have some hesitation. Does that mean that the high side is slipping? For some reason I was thinking that high was direct drive so could the actual clutch be slipping? It does seem to bog down a little bit when going and slam on the brakes. Thanks,Zach |
| mkirsch
11-15-2012 11:47:39
64.80.110.75
Re: 806 TA in reply to farmallzach, 11-13-2012 16:51:25
| TA is basically a two-speed powershift.
It gives you an extra speed between each main gear.
IH never put TAs on tractors as small or old as the A, so you're not missing anything on your tractor. |
| PretendFarmer
11-15-2012 11:31:12
192.249.47.207
Re: 806 TA in reply to CJ Johnson, 11-13-2012 16:51:25
| Yea. My A doesnt have anything like that. How does it work? Is that were you have another shifter for a high and low range? |
| W.Brehm
11-15-2012 09:03:01
63.152.77.106
Re: 806 TA in reply to bwholl, 11-13-2012 16:51:25
| Quoting Removed, click Modern View to see
Torque Amplifier |
| PretendFarmer
11-15-2012 06:14:42
192.249.47.207
Re: 806 TA in reply to Nebraska Cowman, 11-13-2012 16:51:25
| Dumb question. What is a TA? |
| mkirsch
11-14-2012 05:49:59
64.80.110.75
| Common point of confusion is there are TWO types of TAs.
Starting with the Super MTA, and up through the 560, the TA was MECHANICAL. If a mechanical TA goes out on the low side, you can run the tractor virtually forever on the high side with no problems.
When the 806 came out, the larger tractors came with a HYDRAULIC TA. Anything made between 1963 and 1985 with a 7, 8, 9, 10, 12, 14, 15, 30, 32, 33, 34, 35, 36 or 37 as the first "digit" in the model number has a HYDRAULIC TA.
The hydraulic TA is a totally different animal. When the low side goes out, the high side is usually not far behind.
IMHO, never buy a tractor with a hydraulic TA that has TA problems unless you plan on replacing the TA immediately. |
| The tractor vet
11-13-2012 18:02:53
75.24.0.62
| The high side clutches COULD be going to lunch along with other things . Like said below could be the main clutch slipping . It could be sucking air and dropping lock up pressure and allowing the direct drive clutch pac to unlock and with the low side out it will give the jerky in and out . So to start off , first make sure your OIL lite is working and that the low oil pressure sender is hooked up on the MCV , a gauge inplace of the sender would be better . Then check pressure on the MCV . Your dealing with a tractor that is starting to get OLD and god only knows how it was treated . And to cure your problems ya may have to replace the T/A MCV pump and the main clutch along with a couple hand fulls of other pieces and parts. Nothing that a couple grand won't fix. |
| Janicholson
11-13-2012 17:16:15
96.24.99.126
| Aim it at a clear stretch of field, put it in road gear, give it 3/4 throttle and let the clutch out rather rapidly (as though you were a novice with a stick shift Falcon). If it rapidly kills the engine, the clutch is probably OK. If it takes off and builds speed till it travels at the throttle setting, the clutch is toast. Jim |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
