| Farmall & IHC Tractors Discussion Forum |
Topic: Re: W4 BLOCK
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| D Slater
11-13-2012 05:12:34
184.15.8.142
They did make W-4 tractors in 53 but you are not lucky enough to have one, its a 50 model. H engine block works, even a SH if installing new pistons and sleeves. Farmall 300 and 350 block can also be used without much work. |
| toymaker 27
11-13-2012 06:36:57
172.218.208.223
Re: W4 BLOCK in reply to D Slater, 11-13-2012 05:12:34
| what extra work is required for a 300 or 350 to fit? |
| D Slater
11-13-2012 09:38:47
184.15.8.142
Re: W4 BLOCK in reply to toymaker 27, 11-13-2012 06:36:57
| For just a block install pistons and sleeves for a C169 and C175 engine. Need to buy the high priced piston pin bushings to put in the 4 rods. Unless you find some C169 pistons left around that use the bigger piston pin then the adapter bushings wouldn't be needed. Install 4 parts in or on the rest of the block. If using dome type pistons check the piston to head clearance with the 4 head. Complete farmall 300 or 350 engine. Change the rear engine plate, front engine cover and the steel plate behind the cover unless it already like the 300, 350 one. Need the engine serial to know that. Also sometimes you can find a front cover on non W4 engines that will work with the 4 front engine support. Run a hose from the valve cover opening to the air intake pipe. Fit the choke rod to the 300 carburetor. Install W4 fan blad. With a original generator you need to change the generator belt length. |
| toymaker 27
11-14-2012 18:54:51
172.218.208.223
Re: W4 BLOCK in reply to D Slater, 11-13-2012 09:38:47
| Is the technical classification for the block that i require a "C" block? if yes is there more than one size C block |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
