Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Painting thoughts?
CNKS
11-12-2012 17:05:13
I use PPG Omni base clear and have had no major problem. I do the sheet metal and the cast. For touching up the cast I have some single stage urethane that matches the base clear close enough. As to the gas tank don't try to paint it clear to the top of the opening. Leave the area covered by the gas cap unpainted. Or if you are afraid of rust cover it with epoxy primer along with the rest of the tank. If the correct police are reading this, yes it gives a brighter finish than single stage urethane -- I like it that way.
David G
11-12-2012 18:26:46
 Re: Painting thoughts? in reply to CNKS, 11-12-2012 17:05:13
CNKS, what is the clear that you talked about?
CNKS
11-15-2012 18:04:15
 Re: Painting thoughts? in reply to David G, 11-12-2012 18:26:46
PPG Omni epoxy, followed by PPG Omni surfacer on the sheet metal, followed by Omni base coat followed by Omni clear. Same on the cast except no surfacer in the cast. I do not mix brands.
